Rotation Parameter of North Arrow
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
HJiang85U97
340 Aufrufe, 4 Antworten
Don't know why, but the rotation of north arrow is not based on the desired point ( center of 2 arcs):
Any help will be appreciated.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: HJiang85U97
what do you mean?
Nachricht 3 von 5
Why are you doing this? Why not just use the nested Family as-is in the Project?
...I mean, I don't have rotation parameters for most Families. I rotate them in the Project if need be.
....FWIW: Typically, 12-o'clock compasses are inserted into Plan Views that are oriented to True North and then when to Views' Orientation is toggled between True North and Project North, the compass follows.
Nachricht 4 von 5
azad.Nanva
I fix your family :
If this is your only desire, but you have more and better way to show your sheets.It depends on you and your way of working
Nachricht 5 von 5
HJiang85U97
THanks!
