Rotation about the x-axis of the section box.
4 ANTWORTEN 4
Nachricht 1 von 5
f.annoscia1XRNMD
363 Aufrufe, 4 Antworten
Good morning,
I would need the section box to be rotated around the x axis, I can only get it to rotate around the z axis.
Does anyone know how I could do?
Thank you.
Tags (2)
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: f.annoscia1XRNMD
No way to do it in Revit.  Can you stack multiple 3d views with 'stepping' section boxes on sheet?
Nachricht 3 von 5
f.annoscia1XRNMD
als Antwort auf: ToanDN
No, I don't need it for views. I have to export only some portions of the model in STL.
I tried to cut the Revit model in Formit, but it doesn't cut...
We should add this function, if the section box can be rotated one way, why not rotate it the other way too?
Nachricht 4 von 5
Uncheck Keep Scene Upright
That get you to where you want to go?
Nachricht 5 von 5
A couple of way:
1.
- Export the Revit model to SAT
- Import the SAT in a new Revit file as an in place generic model
- Create a void or a solid mass to cut the SAT with
2.
- Import the SAT in a Mechanical Equipment family and load it in a new Revit model
- Rotate the family along X axis and apply a section box
