Rotating Project North - Some Objects Don't Rotate
27 ANTWORTEN 27
Nachricht 1 von 28
jonalyn_abraham
4724 Aufrufe, 27 Antworten
We are currently the interiors architect for a pretty huge 2015 project (400mb). The AOR did not rotate the project to project north which would have caused a whole lot of issues when beginning to detail out each space. Long story short, we decided to rotate to project north but now have to rotate it back.
When I rotate the model back, it goes well, until I realize that seemingly random objects do not rotate. This is a problem, because certain pieces of furniture rotate and others don't. Any suggestions?
27 ANTWORTEN 27
Nachricht 2 von 28
als Antwort auf: jonalyn_abraham
How were those other families created?  I have seen this issue when DWG's are inserted in a family instead of using native Revit construction.
Nachricht 3 von 28
jonalyn_abraham
als Antwort auf: Anonymous
Definitely not with DWGs. They are pretty simple families, mostly casework, generic models, and specialty equipment.
Nachricht 4 von 28
Simon_Weel
Same thing here. As you say, rather random object are not rotated; generic models, furniture, plumbing fixtures. If _none_ of those families was rotated, we had a pattern. For example, there's a table (furniture) with chairs (furniture) around it. The table is rotated but not the chairs. I checked those families and I don't see anything odd. So I wonder what the explanation is for this 'feature' and how to resolve it.... (yes, I know, start modelling the right way in the first place).
Simon
Nachricht 5 von 28
Sahay_R
Shot in the dark - group objects? Maybe one humongous group of the entire project? At the very least try grouping the non-rotators with the rotators?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 6 von 28
Simon_Weel
als Antwort auf: Sahay_R
Yes, tried that too, but no - it won't budge. Also tried linking the file into a new file, rotated the link, then bound it. After the bind-operation, everything is rotated, but a lot of stuff is deleted (like curtain walls). So unfortunately, that's no work-around too.
Luckily, the project in question had just started, so there wasn't a lot of stuff to rotate. We rotated  'Project North' and then manually rotated the left-overs. Everything turned out fine, but it took a lot more time then we expected.
Simon
Nachricht 7 von 28
als Antwort auf: Simon_Weel
am i missing something here - project north is not something that can be rotated? as best i know..... its just a description of the model orientation as it sits in model space. project north is simply 'up/down' page and is a notional device for describing how a view-port will appear on a page/sheet. TRUE north is then rotated by describing the difference between project north (page orientation) and true north (real world orientation)......
if you want the viewport to orientate differently on the sheet without rotating the entire model (which seems to give you an overhead to fix) then you can simply rotate the viewport on the sheet to get the orientation you want????
Nachricht 8 von 28
Simon_Weel
Yes: Click Manage > Position > Rotate Project North.
Simon
Nachricht 9 von 28
RobDraw
A viewport can only be rotated 90 degrees and text rotates with it. Not good for standard drafting practices.
Rob
Nachricht 10 von 28
He meant rotating the view's crop region, which is able to be rotated at any angle. It's different than rotating a viewport on Sheet.
Nachricht 11 von 28
haha
yes i have missed something - however - having tried it (now) i cant help but notice that its not project north that rotates - its most of the elements within the model that rotate within the project north..... most - being the operative word here......
Nachricht 12 von 28
kadmonkee
are the effected elements , components or families pinned?
are any of the families modeled in place families?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 13 von 28
Simon_Weel
@Anonymous wrote:
cant help but notice that its not project north that rotates.
Yes, Rotate Project North is quite ambiguous. It should be Rotate Project just as Mirror Project. Anyway, now you've seen what happens; any clue for a cause?
Simon
Nachricht 14 von 28
Simon_Weel
als Antwort auf: kadmonkee
No and No.
Simon
Nachricht 15 von 28
unfortunately not.... i had a similar thing with 'rotate project' and discovered the workaround to rotate the crop region. it was the easiest and quickest way for me to get the results i needed - otherwise i would have had to go to each piece that hadnt rotated (having 1st checked and found them all!!) and do a manual rotate... on a 350mB model this wasnt practicable
and so i worked out the rotate crop region workaround....
Nachricht 16 von 28
Simon_Weel
Nachricht 17 von 28
this answer is from 2014. The Revit 2017 should be able to rotate everything, I guess.
Nachricht 18 von 28
Simon_Weel
Unfortunately: No. Just tested Revit 2018 and still the same.
Simon
Nachricht 19 von 28
pieter1
I just had this happen in Revit 2020.
Seemingly random objects are left behind ( a few hundred of them). Some are in design options, some are in the main model. Different types of families, regular and inplace.
As far as I can tell they don't have anything in common.
I also found that it deleted a couple of elements. I know for sure because I made a backup just before and just after rotating project north and a few inplace models are completely missing from the rotated model.
Nachricht 20 von 28
als Antwort auf: pieter1
This is not new. I would avoid rotating project north at all cost and to be honest, I have never found a good reason to do it.
