rotating problems
1 ANTWORT 1
Nachricht 1 von 2
Arno.delange
169 Aufrufe, 1 Antwort
rotating problems
In Revit 2022 i have sometimes a problem with rotating.
When i want to rotate something 180 degrees... i need to fill in 90 degrees to get it rotate 180 degrees.
It doesn't happen all the time.. i have not figured out in what situations it does and doesn't
It is very annoying..
Do other people encounter this problem as well?
1 ANTWORT 1
Nachricht 2 von 2
ennujozlagam
als Antwort auf: Arno.delange
can you please elaborate more? what do you want to rotate? if you to rotate a family > go to edit your family and uncheck always vertical in the properties. or click the object > go to rotate icon > click on your screen (line will appear) then you can rotate. thanks
