Rotating linked DWG file when adding them to sections?
torkild.alstad
Observer Observer
torkild.alstad
Observer
Observer
Hello, I am linking in some sections views from DWGs to Revit.
How do i rotate it around the horizontal axis in an elevated view?
Can I do this in Revit or do I have to go and fix it in Autocad/civil?
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @torkild.alstad ,
it sounds that your inquiry is related to this article in the Autodesk Knowledge Network:
http://knowledge.autodesk.com/article/Elevation-drawings-of-imported-DWG-file-not-visible-in-elevati...
Please, check if the suggestions in the article allow you to resolve this request.
Don´t forget to mark this post as a solution if it does - this way you can help others to find the answer more quickly.
Best regards,
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
You should link it in with the box "Current view only" checked.
