Rotating entourage in the desired direction for rendering
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
sj3D42P
982 Aufrufe, 11 Antworten
Hi, I'm trying to render two people in the render, one of them viewing to the left and the other one viewing to the right or at different angle but when rendered, they both look at the same direction. I already rotated them in the plan view. How do you tell them to keep facing to a desired direction? see image below, Thanks in advanced.
Beschriftungen (4)
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: sj3D42P
Pin 'em.
...after you rotate 'em.
BTW: Spacebar Rotate also works. if you weren't aware.
Nachricht 3 von 12
sj3D42P
als Antwort auf: barthbradley
Thanks for the advice but still they rotate in the Rendering after pinned, see below. Thanks.
Nachricht 4 von 12
I don't understand what you are saying.  "They rotate in the Rendering after pinned"?  That doesn't compute.
Try messing around with the Cast Reflections Property. Dunno. Just spit-balling here.
Consistent Colors - Realistic - Render for me.
Nachricht 5 von 12
sj3D42P
If you see the floor plan, I have all of them (entourages/people) facing to the left, meaning that the camera for the rendering is behind them, I want to see their backs.
When I render them, they always face the camera, is it possible to make them face in any direction except facing the camera? thanks.
Nachricht 6 von 12
See my edited post.  I'm not sure what's going on at your end.
Nachricht 7 von 12
Try some other RCPs, may be what ypu use don't have full 360 degree images.
Nachricht 8 von 12
sj3D42P
Now that you've added these three images of the same Entourage, you might better understand what I'm looking for.
Simply try this, send those three images again but not their faces - I want to see their backs, that's what I meant by rotating the RPC.
Thanks.
Nachricht 9 von 12
Realistic view 2022.  You just need to choose the RCPs with front/back/side images.  Not all do.
Nachricht 10 von 12
Nachricht 11 von 12
Oh, I see what you are talking about. REALISTC View - not Rendered View. Yes, Archvision's Entourage is a very positive people. They are always looking forward - not backwards - in Realistic View.
All joking aside, I don't know what gives here.  Seems to be a 2022 thing though.  It's not happening in 2020.
Nachricht 12 von 12
2021 also.
Real-Time Realistic was introduced in 2021.  There must to be a correlation.
