Rotating an Object Revit 2022
11 ANTWORTEN 11
Nachricht 1 von 12
IMCornish
1858 Aufrufe, 11 Antworten
It used to be very easy to rotate and object after it was placed but now, in Revit 2022, if I do not rotate the object when first placed, it will not rotate it but a warning will be given that two identical objects are in the same place. See below
Any ideas
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
11 ANTWORTEN 11
Nachricht 2 von 12
scott_d_davis
als Antwort auf: IMCornish
check the options bar...are you leaving "copy" checked on when using rotate?
Scott D Davis
Sr AEC Technical Specialist
Nachricht 3 von 12
neil_dodsley
I am finding the same issue.  I have a "pipe accessories" system family for a valve. In Revit 2018. as a stand alone component I can rotate it to any angle in plan view AND I can rotate it to any angle in section view  ...  In revit 2022 ... same scenario but it will not rotate in section view.
"Generic" families have always refused to rotate in a section view (Z plane) but "pipe accessories" and "pipe fittings" have always rotated until now.
If anyone has any answers please. This is crazy
Nachricht 4 von 12
jsanders
An old trick in the book is to create a group of the object, rotate the group, then explode the group. Could be worth to give it a try.
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Nachricht 5 von 12
als Antwort auf: neil_dodsley
No issue here.
Nachricht 6 von 12
whbouwmeester
No solution, but also weird things happening when rotating:
rotate an object (workplane: level, view: level), center of rotation in the corner
input:
result: object has an offset from the center of rotation.
Also: rotating multiple objects (workplane: level, view: level) without changing center of rotation:
When typing 90° or manually rotating 90° the objects rotate 180°. When typing or rotating 180° the objects rotate 360°
input:
result:
@scott_d_davis
Nachricht 7 von 12
jbenedetto
als Antwort auf: whbouwmeester
I'm having the same issues in Revit 2022 working with an .rvt upgraded from 2021
Nachricht 8 von 12
jbenedetto
I solved this by deselcting "disjoin" in the options when rotate command is initiated:
Nachricht 9 von 12
justin.e.kyle
als Antwort auf: jsanders
Thanks for the work around. One day I can only pray that Autodesk actually fixes their software instead of relying on its user base to memorize a series of exceptions and work arounds.
Nachricht 10 von 12
IMCornish
als Antwort auf: scott_d_davis
No
Andrew Robertson
Chartered Architect
Truro. UK
Nachricht 11 von 12
J_BIM
I'm getting the same issue. simply rotating any level hosted object just dosn't work.
I first noticed a chair not rotating in a plan, so I swaped it out for better family, no difference.
also having the issue with Casework and Entorage category familys (anything level hosted).
does not work regardless of "Disjoin" ticked or unticked.
If I have "copy" ticked then I just get 2 elements in the same place, no rotation, and a warning about identical instances.
it's only when the host is on something other than a Level.
e.g. a surface or a floor.
Tags (2)
Nachricht 12 von 12
als Antwort auf: J_BIM
