Rotating a view
21 ANTWORTEN 21
GELÖST
Nachricht 1 von 22
jacques
2454 Aufrufe, 21 Antworten
Rotating a view
Does anyone know of a view to rotate an RCP say... 15 degrees instead of 90 degrees?
21 ANTWORTEN 21
Nachricht 2 von 22
als Antwort auf: jacques
Draw a scope box, rotate it, and assign it to the view.
Nachricht 3 von 22
jacques
als Antwort auf: ToanDN
I thought "scope boxes" only works with floor plans?
Nachricht 4 von 22
chrisplyler
That's not correct.
Nachricht 5 von 22
jacques
als Antwort auf: chrisplyler
Ok, that was cryptic. Care to elaborate?
Nachricht 6 von 22
Your assumption regarding scope boxes applications is incorrect. Try it with RCP and see.
Nachricht 7 von 22
Perhaps I'm missing something with the question. You can rotate any plan or RCP by simply selecting the Crop Region of the view, use the rotate tool, and type in any angle. Keep in mind, you are rotating the view and not the elements, so you need to rotate the opposite direction of what you think.
Using a scope box works too, but seems like extra steps to me.
Nachricht 8 von 22
als Antwort auf: Anonymous
@Anonymous
You are correct.  If a view is set to Project North then you can rotate its scope region directly and save a step.
But if it set to True North, then you have to change it to Project North first before you rotate the scope region, at which point you may have to recalculate the rotation delta again.  Or you can just assign it to a rotated scope box and be done.
Nachricht 9 von 22
jacques
Tried that starting from a floor plan, then converted to RCP. Yet it made no difference. The RCP looked no different than the floor plan. The other choice would have been to change the project north. And that would have created problems for the other RCPs. At the end, we gave up and used a smaller scale.
Nachricht 10 von 22
You cannot convert one View type to another, i.e. Floor plan to RCP, section to elevation, etc. Rotating Project North is obviously the wrong approach because it affects the entire project, not just one or some views. You could certainly rotate any RCP views the same as with Floor Plans. Perhaps that view had been associated with a scope box already and it prevented you from rotating it.
Nachricht 11 von 22
Rotate RCP view:
Nachricht 12 von 22
jacques
See, in our models, the option to associate a view with a scope box is "greyed out" for all RCPs. That is why we could not get it to work. We can do floor alright.
@ToanDN wrote:
Rotate RCP view:
Nachricht 13 von 22
Are RCPs using a view template?  Are they True North?
Nachricht 14 von 22
jacques
No template, true north,
Nachricht 15 von 22
You cannot rotate true north views. Must change them to project north first.
Nachricht 16 von 22
RobDraw
That is not a solution. It's not even a workaround. It's giving up. I hope you try to do it the right way as described @ToanDN after you marked this as the solution.
Rob
Nachricht 17 von 22
jacques
als Antwort auf: RobDraw
Project north or true north, it didn't work. Scope boxes just don't work with RCPs.
Nachricht 18 von 22
I would ask you to delete all sensitive data and share the file but you would probably say no.
Nachricht 19 von 22
jacques
It would take a while to clean up the file. But, we can post it.
Nachricht 20 von 22
Go to a 3d view and delete all model. Delete all Sheets and all views except for the RCPs.
