I've linked an image into a plan view and rotated it slightly.
The cropped view on the sheet looks fine in Revit, but when printed, the cropping appears to follow the image rotation.
This occurs when printing to pdf using various pdf drivers and readers. I've not tried printing to a printer directly from Revit. We just don't do that anymore.
I even tried placing some masking areas around the image, but even those don't act right.
Please see image. Left is Revit, right is PDF. Masking not applied in this image.
Gelöst! Gehe zur Lösung
Gelöst von j0258169. Gehe zur Lösung
Just a suggestion, because I can't replicate the problem:
Sometimes when we have issues printing to PDF (problems with images, masking, hatches, etc) exporting to PDF (if you're in a recent version of Revit) instead of printing to PDF seems to correct it.
