Rotated images messes with view crop
2 REPLIES 2
LyleHardin
137 Views, 2 Replies
I've linked an image into a plan view and rotated it slightly.
The cropped view on the sheet looks fine in Revit, but when printed, the cropping appears to follow the image rotation.
This occurs when printing to pdf using various pdf drivers and readers. I've not tried printing to a printer directly from Revit. We just don't do that anymore.
I even tried placing some masking areas around the image, but even those don't act right.
Please see image. Left is Revit, right is PDF. Masking not applied in this image.
Labels (3)
2 REPLIES 2
j0258169
in reply to: LyleHardin
Just a suggestion, because I can't replicate the problem:
Sometimes when we have issues printing to PDF (problems with images, masking, hatches, etc) exporting to PDF (if you're in a recent version of Revit) instead of printing to PDF seems to correct it.
LyleHardin
Ha! That worked. We use that all the time for multiple sheets, so I don't know why I didn't think of that. Thanks @j0258169 !
Forma Design Contest
Technology Administrators
