Rotate with Component
4 ANTWORTEN 4
Nachricht 1 von 5
GHASEM_ARIYANI
393 Aufrufe, 4 Antworten
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: GHASEM_ARIYANI
I can confirm - component is rotated.
Nachricht 3 von 5
martijn_pater
Select both and then rotate. :zwinkerndes_Gesicht:
Nachricht 4 von 5
bin
Work plane.
Nachricht 5 von 5
Lance.Coffey
For reference, there has been a change in this behavior in the 2021 version: Rotate Tag with Component
If reporting problems or success it would be useful to specify the version you are working with (along with the details of what you are doing, the unexpected/expected result you are seeing, and sample files where possible).
Lance Coffey
Technical Support Specialist
