Gelöst von mauricio_mssf. Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
Gelöst von mike_tomasurvey. Gehe zur Lösung
Gelöst von LyleHardin. Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
NO NEED TO SHOUT!
@jorgedacunha60 wrote:HOW DO YOU ROTATE VIEWPORT WITHOUT ROTATE TITLE ON SHEET?
Have you tired rotating the crop region?
so as RobDraw already mentioned:
Constantin Stroescu
Get 'inside' the view. Pick on the crop boundary as if you are going to edit it. Rotate it. Then adjust it as necessary.
It will rotate the view OPPOSITE the direction you rotate the frame, so it takes some getting used to.
Sorry, I am not sure why I got an email to help. Didn't realilze this was a Revit post. Wierd. I have deleted the post. Sorry again.
Mike
Those AutoCAD commands will not work in Revit!
Follow these steps
1 - Click on Show Crop View
2 - Modify the view orientation for Project North
3 - Select the viewport and rotate.
You can see in the screen video
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/27a...
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
