ROTATE VIEW ON SHEETS?
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
517 Aufrufe, 9 Antworten
I have 3 standalone small shelters on a single site but all 3 shelters are at different angles.
Pls advise what is best way to show all 3 building plans views in a single sheet but plans have to be ortho.
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
If you have each of the buildings as separate floor plans you can unhide the crop region for each view, then rotate it to the correct angle and hide it again.
Nachricht 3 von 10
Just a note, you need to rotate the crop region the opposite way you want the buildings to rotate
Nachricht 4 von 10
Thanks Alex and SKoulis.
Alex, sorry I dont know its a dumb question but all 3 shelters are on same level so how do I model as different floor plans? Thanks
Nachricht 5 von 10
If you right click on the view and duplicate it as dependent 3 times (and rename as appropriate), then crop down each view so it only shows one of the buildings. You can then leave the original view showing all 3 buildings.
Nachricht 6 von 10
Alex,
Do you mean to duplicate floor plans views just for purpose of rotating crop views?
I tried using callouts but noticed that my CAD link survey plan doesnt appear on callouts. How do I make CAD link visible?
Thnaks
Nachricht 7 von 10
yes. duplicating as dependant should keep any annotations or cad underlays consistent on all the views
Nachricht 8 von 10
Oh OK Alex, thanks for fast answer to my 1st question.
Is there a way to make CAD links visible in Callouts?
Nachricht 9 von 10
if you copy it, then paste aligned to the same place it should work
Nachricht 10 von 10
Thanks Alex
