Rotate UV grid 90 degree and 3d sweep
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
589 Aufrufe, 2 Antworten
How can I rotate the starting point on this divided surface as shown in the attached image?
Also, how can I make a sweep / mass along the following lines? I can get a 2d sweep but not on 3d.
Scott
Tags (2)
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Use Nodes and 3D Snapping to draw your Sweep Path.
Nachricht 3 von 3
als Antwort auf: barthbradley
Thank you, I have got everything drawn, now. It required breaking down into sections due to an error, but now done!
