Is there a way to rotate the text box using the align tool? So we can align the text box with an angled line or component.
No, not just the align tool.
You can use the Rotate command if you know the angle. You can also use a detail line and group it with the text...then the Align command will "see" the line. If I have a lot of text to deal with at an angle then I get one right and copy that one over for the rest and change the text.
I find that most of the time I can just "eyeball" it with the text's rotate grip and it would be hard for anyone to tell if it wasn't aligned with the adjacent information.
Steve Stafford
