Rotate skylight grid
6 ANTWORTEN 6
Nachricht 1 von 7
620 Aufrufe, 6 Antworten
Using a mass, I am creating a skylight, but the system is make the grid at weird angles if I use a trapezoid shape. If I make the mass as a rectangle, is it okay. How do I make it like the red marks on the screenshot?
Any and all help would be appreciated, as always! Thank you
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
What about Sloped Glazing? You can change the Angle with that one.
Nachricht 3 von 7
constantin.stroescu
you can use Align tool . Align > Select a Face or Edge you want to align with and then select a Grid Line.
Constantin Stroescu
Nachricht 4 von 7
constantin.stroescu
  • I've made some diggings and it seems that, the clue is to begin the mass element as a rectangle
        Then Create Form >Solid Form , and finally stretch Edges so to turn the paralelipiped into your desired volume.
         I figure that Revit remember the object as an extrude rectangle and Aligns correct the Grid.
  • It is possible to Align Grid to Vertical Faces , but you will need for the second Grid Line a Model Line placed on the Face of the Grids so to be the second reference for align .
Constantin Stroescu
Nachricht 5 von 7
Nachricht 6 von 7
Can you share the file?  I did a test and the UV grid of a divided surface seems to have the right angle.
Regardless, you can adjust the UV grid, including rotation, alignment, etc. by activating the grid configuration tool.
Annotation 2019-01-20 140911.jpgAnnotation 2019-01-20 141204.jpgAnnotation 2019-01-20 141220.jpg
Nachricht 7 von 7
als Antwort auf: ToanDN
I'll try the sloped glazing and subdivide.
In the mean time, here is file
