Rotate "hollow profiles" on revit ?
6 ANTWORTEN 6
Nachricht 1 von 7
jsanders
766 Aufrufe, 6 Antworten
In revit, when you choose the tool "hollow profile" (I don't know how to call it in English) it offers 2 options, either vertical profile or horizontal profile. However, I have some that are neither, they are at a certain angle. How can I do this ?
Here is a screencast of what I mean.
Thank you for your help.
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: jsanders
You mean the wall reveal? For angled ones, use a line based or face based or wall based family with a void sweep.
Nachricht 3 von 7
Corsten.Au
Wall Inplace Void.JPGWall Inplace Void1.JPGHi
If you have multiple design then create a family mentioned by @ToanDN.
and if you have just one off void / reveal cut, then you can use
"in-place"family, select the wall as the plane, create a profile, give a thickness ( Void )
Cut that void "Cut Geometry "and select the wall, so that voids cuts the wall..
Cheers!
Corsten
Building Designer
Nachricht 4 von 7
jsanders
als Antwort auf: Corsten.Au
Thanks I'll have a look and let you know.
Nachricht 5 von 7
Viveka_CD
Hi @jsanders
I just wanted to follow up here, any progress on this issue?
Did you have a chance to try the recommendations of the experts?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Nachricht 6 von 7
jsanders
als Antwort auf: Viveka_CD
The revit expert in our company created a family that made a hole in the wall so that I get a hollow profile like I want. Unfortunately it has to be hand made and therefore the profile tool in Revit is useless. This should be updated in the current build.
Nachricht 7 von 7
Viveka_CD
Hi @jsanders
Thanks for getting back to us.
You may submit your request through our IdeaStation
The product team will review this request and take it into consideration for further development.
Please follow up here and post the link after you've posted to the Ideas forum.
Thanks in advance.
