As of Revit 2024, is there a way to rotate a group on placement, like you can with other objects (spacebar)?
To clarify, I don't want to be forced to place the group, use the rotate tool to rotate it and move it again. I mean rotating the group (90º) before chosing a pick point to place it.
Gelöst! Gehe zur Lösung
Gelöst von Ryan_GormanKT36T. Gehe zur Lösung
Thank you Ryan. Unless someone else comes to prove us wrong, I'll mark your answer as the solution.
