@emersongonzalez1999 wrote:
How would I turn into a non-hosted family so I can move where ever I want and also change the dimensions.
- Edit the elevator family and change to Mechanical category
- Load it back in and close the family w/o saving
- Create a new project, link your project in
- Copy monitor the elevator in
- Edit the family (it is now a face based family), select solid host and change extrusion thickness to 0 and accept deletion
- Change the family back to Specialty Equipment category, save as to a new name and load it in your project
With that said, I have seen a lot of wall based elevator families and for a good reason. That is so the location of the elevator car and elevator door is constrained properly to the front wall of the elevator shaft per manufacturer's spec..
