Rotate/convert hosted wall in family
4 ANTWORTEN 4
Nachricht 1 von 5
yes_and_no
284 Aufrufe, 4 Antworten
I developed a family with fair amount of child families. It was a side wall hosted configuration.
After testing, I learned that it s better be a backwall hosted family.
Q: is there a simple way to make the hosted wall rotated ? Or simply put, making the family from sidewall hosted to backwall hosted, in an easy way ?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: yes_and_no
Don't understand what you are describing.  Side Wall Hosted?  Back Wall Hosted?  Maybe pictures would help.
Nachricht 3 von 5
yes_and_no
als Antwort auf: barthbradley
Posted in OP
Nachricht 4 von 5
Rotating it side-sides?  Create two types; one rotated 90-degrees and the other not rotated and control visibility via a Yes-No Parameter. That would be the easiest way - but not the only way.
Nachricht 5 von 5
How about converting it to non host family altogether and use Cut geometry manually where you want?
