Rotate Conceptual Mass?
22 ANTWORTEN 22
GELÖST
Nachricht 1 von 23
PhilvK
7755 Aufrufe, 22 Antworten
If I create a Conceptual Mass in the Front/Back plane (1st image), how do I rotate it in plan in the Level 1 plane (2nd image)? This has got to be easy, but I cannot figure it out! Thank you.
22 ANTWORTEN 22
Nachricht 2 von 23
als Antwort auf: PhilvK
Hi PhilvK,
Since your mass profile is on the front/back plane I will suggest that you will rotate the plane. if you don't want to rotate your front/back plane you can create a new one.
Check this out: https://screencast.autodesk.com/main/details/bf84f59d-79c9-4b43-86d8-c1f408c0ead4
Anyway, if you wanty to add some parameters to your family, you have to create a network of reference lines and to draw your mass profile on the reference plane of the reference line. (till now I couldn't find a way to rotate a reference plane with parameters).
check the video below and the attached file:
https://screencast.autodesk.com/main/details/f150fa0d-f57c-412b-ad62-8fec74c3ff78
Hope this helps!
Lucian
Nachricht 3 von 23
PhilvK
Is the answer to this: You can't rotate it becasue it was created in another reference plane"?
Nachricht 4 von 23
PhilvK
I posted my quick reply before I got yours. Thanks again!
Nachricht 5 von 23
I think  that the mass is locked on the reference plane of the mass profile.
Nachricht 6 von 23
PhilvK
als Antwort auf: Anonymous
I believe you are right.
Nachricht 7 von 23
scott_d_davis
you *can* rotate it, but it will require you drawing a Ref Line first (ref lines have endpoints and will rotate).  A Ref Line is made up of 2 Ref Planes, one horizontal and one vertical.  Set the workplane to the horizontal plane of the Ref Line, then sketch your shape.  Then, you will be able to grip one endpoint of your Ref Line to roate your shape off the "base" plane.
Scott D Davis
Sr AEC Technical Specialist
Nachricht 8 von 23
Alfredo_Medina
als Antwort auf: scott_d_davis
The previous solutions suggest that the user should have done something before creating this mass, but what would be the solution now that this object has already been created, without starting over?
Nachricht 9 von 23
als Antwort auf: Alfredo_Medina
Just simply to rotate the plane on which the mass profile was created.
Nachricht 10 von 23
Alfredo_Medina
My point is that the solutions that have been presented suggest that the user has to start over, create either a reference plane or a reference line and then create the form. That´s miy point, that this suggestion of going backwards in the process and redoing the form is not necessary.
Nachricht 11 von 23
Hi Alfredo,
Until now, I couldn't find a solution to avoid the rework. Since my theory is that the mass profile is locked on the reference plane I'm thinking maybe my thought are foggy.
Another option I can think to is to insert the already created mass in another mass. Then the rotation isn't a problem anymore.
Anyway, if you already know a method which was not presented and will help us to avoid to step back in design process, would be great if you can share it with us.
Lucian
Nachricht 12 von 23
Alfredo_Medina
Hi, Lucian,
Yes, there are some alternatives to rotate this or any object without having to start over and without nesting into another family or without rotating the center front/back reference plane which might be necessary to stay there for other things. I will make a video this evening after work to show those options.
Nachricht 13 von 23
PhilvK
Lucian and Alfredo -
For whatever it’s worth, I got a little impatient and quickly constructed my mass in Autocad and imported it into Revit. Very easy to do, and I can copy and rotate it to my heart’s content! As I explained in my response to another thread I came across having to do with importing 3D masses, the ease of this may have to do with my Autocad experience, and being new to Revit. Nonetheless, I will continue to see why Revit can’t seem to be able to be as flexible. Thank you both for your continued respsonses.
Nachricht 14 von 23
I look forward!
Nachricht 15 von 23
Alfredo_Medina
That's all right, Phil, but if you really want to work on Revit, at some point you need to learn how to do everything in Revit. Those "shortcuts" from AutoCAD, in the long run, are not a good idea. I will post a video tonight explaining the options for this rotation.
Nachricht 16 von 23
PhilvK
I agree with you!
Nachricht 17 von 23
Hi PhilvK,
Check this video:
https://www.youtube.com/watch?v=8Y8FcHV8HHk
Based on this ideea I made another video. So as Alfredo said, is not always good to get back and reconstruct what you have done. So, using this option, you have only to change the host of your mass.
Check this out:
https://screencast.autodesk.com/main/details/47a10a63-05f9-478d-a75f-ea9ad708b4f1
Lucian
Nachricht 18 von 23
Alfredo_Medina
This video describes two methods:
Nachricht 19 von 23
PhilvK
Alfredo - Excellent video, and very informative! Thank you for taking the time to produce it.
Nachricht 20 von 23
PhilvK
Darn - did it again: accepted my reply instead of the solution! Forum moderators feel free to correct it.
