Rotate callouts along wall
3 ANTWORTEN 3
Nachricht 1 von 4
Marcus.Isacsson
681 Aufrufe, 3 Antworten
Hi fellas!
Any trick to rotate a callout correctly? Want it to follow the rotation of the walls.
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Marcus.Isacsson
hello, you can try to refer to this LINK. thanks
Nachricht 3 von 4
When you rotate, drag the anchor point on the wall so that you can snap the rotation precisely. After that, move the callout to where you want it.
Nachricht 4 von 4
Sahay_R
Select the callout and go into Edit Crop, which will allow you to do all kinds of weird, wild, and wonderful things - namely Rotate and / or Align.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
