is it possible to rotate a bulding's orientation just for a specific view? I know you can rotate the building using 'rotate project north' but that rotates the building in every single view and i just need to rotate it for just one view because I need the drawing to fit on a specifc sheet with a specific scale and the only way to achieve that is rotate the building in a way that would fit on the sheet. I also don't want to touch the project's true north as that has been set to real world coordinates.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
