hi, I've created a family with a adaptive generic model to fit in a mass surface as you can see in the pictures, i need to rotate the panels so these can be horizontal and not obliques as you see.
Have a look at the family and at the family detail, Revit doesn't allow me to rotate or align the extrusions to meet my needs even if i set the work-plane horizontal.
@Irreb Hi
i cannot see much from the quality of the images...all pixelated (add to that the mobile viewing factor) BUT try to replace it using a different order (ie:either start from a different node/corner OR relabel the numbering order of the placement points)
Sent from my iPhone
hi RDAOU, i've already tried these ways, nothing change except for the angle (that has to be horizontal) and the way that it changes seems to have no matches about how you insert the family in the project or similar
