Hi
I have a ram from between Ground Floor and Basement where I have a Garage. I can't rotate or align the car to this ramp. I already chose to ramp as a new host for the car. Please Please I need step by step solution because I'm new to Revit.
Many thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von zs-17. Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
The car needs to be Work Plane-Based and the Ramp selected as the Workplane when placing the car on the ramp.
Open the Car Family and uncheck Always Vertical and check Work Plane-Based and the re-load into Project. When placing car in the View, take note of the 2 Placement Options: select the one that says place on Work Place and then pick the Ramp surface.
Also un-check the option for Always Vertical while editing the family.
Steve Stafford
Great. So how it works here, is that you mark an accepted solution to close out the thread. Looks like two people got here with the same suggestion that worked for you, so you might what to accept both solutions.
Cheers!
