Rotate a "model in place" object
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2151 Aufrufe, 3 Antworten
I've got tons of good advices already so if you dont want to answer I'm totaly fine with that, but th problem is this. I'm trying to rotate a cylinder shaped object in my project, but always get the same answer no matter what view I'm in, "Can't rotate element into this position" What am I to do???
I'll submit a foto of what I'd like to do and my revit file
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Probably modeled on a plane perpendicular to the plane you want to rotate it on.  You need to recreate on the different work plane. Probably best to model as loadable a work plane based family.  That way you can host additional instance of it to different named work planes in the project.
Note: if you do model it as a loadable family check Work Plane Based and uncheck Always Vertical in the Family.
Nachricht 3 von 4
FAIR59
make a group of the in-place object, rotate and ungroup
Nachricht 4 von 4
als Antwort auf: FAIR59
Worked perfectly!!! Thank you :leicht_lächelndes_Gesicht:
