I have a dormer as family made, but it's flat. Is there a way I can change this so that it's standing up the way it's suppose to be?
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Depends a bit on the family category. Some categories are easier to rotate. Also face based or workplane families are easier to position on different axis.
It is also possible to model your family in such a way that it has one or more rotation parameters.
However this is normally done for families that do not have a fixed axis
If your family always needs to be upright the typical/easiest solution is to (re)model your family on the proper axis.
Louis
Please mention Revit version, especially when uploading Revit files.
That's what I was afraid of. Did not realize until I was done. But thank you for clarifying.
