Dear Community,
Does anyone know how I can rotate this nested element:
When I lock my Handle (nested 2D Detail Item family) to Reference Line I get Remove Constraints exception...
I attach sample Family (Revit 2022)
I am pretty sure there must be a configuration that allows this....
Thank you very much for any input
Gelöst! Gehe zur Lösung
Gelöst von kostask_oionei. Gehe zur Lösung
I have put a zero dimension vertical and a zero horizontal and I locked them.
And the angular parameter again in the handle.
I think that works.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
You can try this one.
Kostas Kouris
Thank you, that worked,
Does it mean, that - when rotating 3d nested families, locked alignment to Reference Line should be used,
but - when rotating 2d nested families, locked alignment throws error, and instead zero length locked dimensions shall be used?
