Rooms in Worksets
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
realfakearchitect
496 Aufrufe, 5 Antworten
Rooms in Worksets
I have interior rooms placed in a work set on Level 1. I want to hide these interior rooms completely and want a shell room, just the overall boundary of the shell space as a room. But when I go to place a shell room, it accounts for all the interior rooms despite closing the work set. Is there any way to completely miss the interior rooms which are on a different work set and place an overall room?
Any response or help is much appreciated
5 ANTWORTEN 5
Nachricht 2 von 6
No, probably what you need is an Area, which is a different tool. An Area can be "over" rooms, but a room cannot be over other smaller rooms.
Nachricht 3 von 6
Appreciate the response. Even if the smaller rooms are in a different work set and I close the work set completely. I would still not be able to add an overall room in a different open work set?
Nachricht 4 von 6
Even if you do that, because the room still exists in the model. The only way you can do new rooms "over" other rooms is if some rooms are in a previous phase. But that can become complicated if your project does not have phases, and I don't recommend creating fake phases just to create rooms in this way. As I said, the entity that can go over rooms is Area, in an Area Plan.
Nachricht 5 von 6
handjonathan
als Antwort auf: realfakearchitect
Hi @realfakearchitect
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Alfredo_Medina helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 6 von 6
realfakearchitect
als Antwort auf: handjonathan
Yes, it has helped with my question. I accepted the solution too. Much appreciated!
