Roomook phases
5 ANTWORTEN 5
Nachricht 1 von 6
GA-LT
487 Aufrufe, 5 Antworten
Roomook phases
Hi, is there a posibility that Roombook extension will take in consideration phases of a project? In my case it calculates surfaces of demolished walls which shuldent be already in this phase.
Tags (1)
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: GA-LT
Check the Schedule's Phase/Phase Filter.
Nachricht 3 von 6
RDAOU
@GA-LT
It calculates everything that is there in the project. You will need to exclude/ignore the Demo
Nachricht 4 von 6
GA-LT
als Antwort auf: RDAOU
this is exactly what I did but if you have hundreds of changes like this it seems that this tool is useless.
Nachricht 5 von 6
RDAOU
@GA-LT
Yeah it would be nice if it would allow for a phase filter option but even without it is not that dramatic and is practically 3 clicks!!
Create a 3D view with Demo only...Then ignore elements using select multiple.
Nachricht 6 von 6
GA-LT
3 clicks in every room (or maybe I do not know something that can allow make it faster everywhere).
I had 200 office rooms to refurbishment so in this case I made temporary model and simply I have deleted all "demolished" walls so all areas of needed surfaces were counted correctly.
Regards
