Roombook Revit 2015
Roombook Revit 2015
caltineller
Message 1 of 10
Roombook Revit 2015
caltineller
I've installed roombook. When I start a new project, the roombook does work. But for an existing project, I get this error.
Any idea?
Replies (9)
Message 2 of 10
robert.klempau
Hello @caltineller,
Did you try to uninstall it and reinstall it?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 3 of 10
caltineller
Yes I did uninstall reinstall it. But this doesn't solve the problem. Libraries are not missing. When I start a new project it works. But for an existing project, (which was created I believe with no template) it doesn't work. I tried transfer project standarts from a blank project to my project, but this didn't work either.
Message 4 of 10
Jacob.westergaard
Autodesk Support
Autodesk Support
Thank you for taking your time to post this on the forum,
I would be interested in checking that file and run it through my own machine - would it be possible for you to share it?
Thanks again,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Message 5 of 10
caltineller
There you go:
https://ft.igairport.com/link/7ZaXeLz4XUVJiZ0yJR2HE0
The file is heavy by the way and I didn't add the links in the file. So if you're able to run the roombook, thats all I want.
Message 6 of 10
Jacob.westergaard
Autodesk Support
Autodesk Support
Hi again,
There's most likely as you mention something missing because it's not based on a template.
I wasn't able to run it either but it worked if I transferred the projects standards from the default template or any other active project so I would suggest you try that.
If it doesn't work for I can do it for you with your live model, the process of transfer took a little moment so don't over react and close Revit, it will eventually get there.
Jacob Westergaard
Message 7 of 10
caltineller
From which template did you transfer standards? And which category did you transfer? I have to do it myself because there are 6-7 models like this in my project. Thank you very much for spending time on this.
Message 8 of 10
caltineller
Works like a charm thank you. But I've selected all categories in transfer. Do you know which category you need?
Message 9 of 10
achusetiawan
Saya masih belum bisa, templat yang mana, boleh bagikan fotonya.
Message 10 of 10
achusetiawan
I still can't, which template, can I share the photo?
