I am a new user on Revit 2020. I am trying to get Roombook to work. But it always launches an alert stating that families are missing. We just re-installed and it still gives problems upon most commands. Which families exactly is it missing?
I notice that the version just installed is build 1104 (2018).
If I use the extension on a new project there are no problems but some conversion is performed from 2018 to 2020.
The paths in Options > File Locations > Places are set and point to the hopefully proper folders in US Imperial (is that even right, and if yes, why US?)
Thank you for your help.
_c_
@Anonymous
In windows explorer, GO to the folder location which you see there under option and make sure it is actually there...and the families are therein
@Anonymous
What if you click OK and try to load it manually?
I tried now to load each of these three:
and they all give me this error:
... this will hopefully help others.
Since the issue was clearly file based -a new project file would not display it, I tried this:
Now I have more questions: I wish to adapt the calculations to the Swiss environment: from DIN 277 to SIA 416 (2003).
The SIA 416 is somewhat between the DIN 277 (1987) and (2016). I would need to:
How do the Swiss colleagues do this? Do you use this extension? Can I simply rename the labels? As I said, I just began with Revit some weeks ago.
Thank you
_c_
