Greetings , i am an architect student from greece and i am trying to learn roombook 2016 for revit. I downloaded english roombook2016 from autodesk and installed it normally. The problem is that when i use din germany and not international and at the same time i use family din_ENU in areabook , when i calculate and export everything is in german. Is this a common problem? In older videos of roombook 2015 with the same choices the export was in english. Looking forward for a decent answer...
yours faithfullly
Panos antoniou
I found sth that explains it perfectly. This is a mistake in the program are i found that in the folder roombook is installed in export>excel>din>enu two of the xls files are in german . It seems they forgot to translate it. Does anyone has the original english files?
