Room Volume doesnt fill the room
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1244 Aufrufe, 3 Antworten
Hello World,
I have one problem and i hope you can help me.
My problem is that my room doesnt completely fills the volume of the room, and i need it for a subsequent export GBXML for HVAC calculations
 - Here is the Room with the normal room inside. (image room 1)
 - And then, following this solution,
https://forums.autodesk.com/t5/revit-architecture-forum/space-volume-in-a-room-with-a-sloped-wall-or...
 - I end up with this (image room 2)
Any ideas why it doesnt work ? the room seems to ignore the other part of the room and to see it as a non enclosed area (image ignored1)
Thank you!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Do you have Areas and Volumes checked?
...Raise your Level's Computational Height
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Nachricht 3 von 4
ennujozlagam
hello, it could be there is a room separator hidden? activate your bulb icon to see. thanks
Nachricht 4 von 4
als Antwort auf: barthbradley
It was the computational heigh
It was to high so it didnt counted the room volume under that heigh
