ROOM TAGS
ROOM TAGS
ROOM TAGS
How can I change the text size of the room tags? as you can see the room tags are so large that it's blocking the walls.
ennujozlagam
hi, you can change you scale so that your room tags become smaller. And you can edit room tag family reduce the size/modified and saveas change to different filename and load into your project. Change your current room tag to the one you created. hope it helps. thanks
I would first look at the scale of the view instead of changing the Room Tag. Look like it is a very small scale so all annotations are way large.
Keep in mind that text and other annotation sizes are in "real" printed dimensions so if for example the tags have a 3mm text label this will appear 3mm printed regardless of the view scale. Changing the scale will change all model elements in relation to the detail ones.
For this reason it is handy to create different versions for tags and dimensions that work well in the scales you commonly use.
