Why all the room tags from above levels are showing in below level in revit?
Make sure your Base Offset for your room tags is set to 0 and that the level they are assigned to is the correct level
room tag is the view element and if you tagged a room in Level 2 for example you can not see it in Level 1 or Level 3 because room tag dependent to views. so I think you mean why you see the room in the level below,right? or i miss something? you can post some screenshot.
anyway did you check the room Base offset or Limit Offset?
