Room tags/names in Dimension
1 ANTWORT 1
Nachricht 1 von 2
RVTing
283 Aufrufe, 1 Antwort
Hi all,
I was wondering if theres a way (potentially using Dynamo) to create a parameter or something of sorts to have a room tag show under a dimension.
So after drawing a house, tag the rooms, then you create dimensions on the outside of the villa, the ones that dimension a specific room will have the room size and room name showing (ie Bathroom), and ones that dimension more than one room will just show the size.
I imagin itd have something to do with linking the room tag to dimension very similarly to how "show opening heights" are linked when they are ticked.
Thank you
1 ANTWORT 1
Nachricht 2 von 2
mhiserZFHXS
als Antwort auf: RVTing
I would think you could swing this in Dynamo, but I'm guessing it wouldn't be simple.
