I have one linked model from the architect. The building has four areas (A, B, C, and D). As you can see the scope box is applied but room tags are appearing outside of the scope box. How come?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Looks like the Visibility Graphics in that View for that linked model are set to By View for at least Annotation, maybe? If that's the case, if at least SOME portion of the Room is inside the crop, the tag from the linked view will show up. You could reset the linked model VG Annotation setting, and then place "real" Room Tags in that view to control their placement and appearance.
are the room tags part of the view? tick your annotation crop and adjust the line. thanks
