Hello..
I am trying to create a family room tag with various text sizes for the room name that can have its visibility adjusted. However, after I tried creating family types and associating them with parameters, the room text label could not be changed to different parameters for each text label. If I try to change one text label parameter, the other text label parameters will also change.
Below this post, I have attached a video that is the problem for me
Thanks...
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
In the Family Editor you will see all elements / annotations etc. By clicking on "Preview Visibility: On" located in the control bar at the bottom left corner, the Type settings will be revealed to you.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
