Room Tags affected by excavated topolosids
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
olimpia.albisetti
224 Aufrufe, 5 Antworten
Hello, I need some help for this issue I'm having. I put room tags in my building but they seem to be affected by the toposolid/topography even though i did the excavation on the parts where the buildind stands. Not only room tags don't show when the toposolid is higher than the room height (if it wasnt excavated), but the parameters change based on this.
Can someone help? thank you very much!
5 ANTWORTEN 5
Nachricht 2 von 6
You could try unchecking the Room Bounding parameter of the toposolid to see if it helps?
Nachricht 3 von 6
Could you explain to me how to do that? I cant find the right window/option for this operation
Thank you for your help!
Nachricht 4 von 6
When you select the toposolid there should be a Room Bounding parameter with a checkbox in the properties palette:
Nachricht 5 von 6
Thank you very much!! It worked
Nachricht 6 von 6
Glad to help!
