Room tag with shared parameter not showing up
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
kreekie
2875 Aufrufe, 14 Antworten
Hello...I have a floor plan with room tags.  The project is using a shared parameter file with parameters "Quality", "Suitability" and "Utilization".  It is a project parameter and it does show up as a parameter on the room schedule.
When I add these 3 shared parameters to the room tag and load into the plan they do not show up.  I have checked that the family and project are using the same Shared parameter file.  Any ideas?
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: kreekie
Did you also add the Shared Parameter as a Project Parameter assigned to Rooms Category?
If so, did you enter a value for it under the Room's Properties?
Nachricht 3 von 15
kreekie
als Antwort auf: barthbradley
yes (and thanks for your reply)
Nachricht 4 von 15
kreekie
and yes the parameters have values
Nachricht 5 von 15
kreekie
when I select the label in the plan there is a "?" where the parameters should show up.  It is not editable like the other parameters in the label.
Nachricht 6 von 15
constantin.stroescu
maybe you have Visibility or a Visibility Parameter unchecked into Project...
Constantin Stroescu
Nachricht 7 von 15
Hmm. Okay.  Post file. Let's take a look at it.
Nachricht 8 von 15
constantin.stroescu
Select the Room and in Properties allocate values ( text value ) to your parameters...
Constantin Stroescu
Nachricht 9 von 15
Select a room, not a tag, in your project and look at its properties. Do you see the parameter that you added to the room tag label?
Nachricht 10 von 15
kreekie
als Antwort auf: ToanDN
yes I do, under the Data category. I even tried to move it to another
category, no lcuk.
Nachricht 11 von 15
The only explanation is the shared parameter for the label is not the same as the parameter added to Rooms category in the project. Let's show a screenshot of the parameter in the project from the Project parameter dialog.
Nachricht 12 von 15
kreekie
als Antwort auf: constantin.stroescu
I didn't think of that, but I checked it and it looks ok
Please type your reply above this line -##
Nachricht 13 von 15
TripleM-Dev.net
category, no lcuk.
Data Category? you mean Rooms category under the Data group....
Select the room, can you see the values for the parameters in the properties panel....screenshot mayby
If you select the parameter(s) is the project parameters dialog is the "shared" option checked and the "Export" button grey, and the Rooms category checked...
Can you post the project (or transfer parameters to another project file with a room and the tag)
- Michel
Nachricht 14 von 15
kreekie
als Antwort auf: TripleM-Dev.net
I will post..I have to leave for a meeting but will surely follow up asap
Nachricht 15 von 15
Same SP File, not same SP.  Is that it?
