Create a floor and try
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You could model main roof and dormer as one single roof.
If your dormer and main are two separate roofs then you can use opening by face or vertical cut opening to cut 2 hole in the main roof where the dormers are (even though the dormers already cut the main roof) so that the room volume can spill through the holes to fill the space under the dormers.
