Room Tag with custom Wall Finish Labels and Shared Parameters not visible in Project
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
2366 Aufrufe, 8 Antworten
I created the Room Tag with Label with Shared Parameters for Wall Finishes , but upon loading into the project, I am unable to see the Values applied showing in the Tag. What am i Missing?Custom Wall Finish Shared ParametersCustom Wall Finish Shared ParametersCant Edit the room tag in the ProjectCant Edit the room tag in the Project
8 ANTWORTEN 8
Nachricht 2 von 9
Ilic.Andrej
als Antwort auf: Anonymous
I ve been busting my head about this, but the answer is quite simple. The shared parameters you used in the family editor (Wall finish 1, Wall finish 2....) are not the same as those you used in the project (Wall finish 01, Wall finish 02....).
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 9
als Antwort auf: Ilic.Andrej
I just checked the source file of Shared parameters, it is the same one. Still i will redo the tag with a new file and double check. Strange kind of error.
Nachricht 4 von 9
Perfect, it works now. Thankyou so much.
Nachricht 5 von 9
Ilic.Andrej
Take a look at these two pictures you posted. The parameter names are not the same. If the source is the same, check parameter grouping (Maybe Wall finish 1 is in one group, while Wall finish 01 is in another...)
Andrej Ilić
MSc Arch
Nachricht 6 von 9
mmckinney45
How did you create this room tag? Everytime I have tried to create one similar to this, it changes all the options even though each wall has its own parameter. I can't figure out how to keep them from all changing.
Nachricht 7 von 9
rnmtsang
als Antwort auf: mmckinney45
Hi… can anybody tell me where or how I can create this tag?
Cheers
Nachricht 8 von 9
rnmtsang
Hi… any chance you can share this tag? Thanks
Nachricht 9 von 9
mhiserZFHXS
als Antwort auf: rnmtsang
The tag is simple to create. You just need to draw it how you'd like and use shared parameters. Make sure you load the shared parameters used in the tag into your project. This would be a great exercise for you to learn how to make any new tag you'd like.
