Room Tag type tracking in schedule
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
kadmonkee
494 Aufrufe, 7 Antworten
is it possible to manage which room tag type is being used in a schedule?
we have tag types that account for gross and net sq ft values.
to be able to assign which tag should be used through the schedule would be a great help.
I am missing a step along the way and I cant seem to figure out how to connect the parameters.
appreciate any help provided.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
7 ANTWORTEN 7
Nachricht 2 von 8
rxi.gg
als Antwort auf: kadmonkee
I think what you want is not possible ;(
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 8
No. Tags are VIEW-SPECIFIC Elements, just like Annotations.
Nachricht 4 von 8
mhiserZFHXS
This might be something you can do with Dynamo, though I'm not 100% sure what your asking. Do you want the schedule to show what tag is used in a given room/area and plan? Or do you want to select what type of tag is used via the schedule? Does the schedule needs to have a cell that changes whether it reads the gross or net area depending on what tag is used?
Nachricht 5 von 8
kadmonkee
als Antwort auf: mhiserZFHXS
thanks for the reply
I am not well versed in Dynamo, only I know it is available.
step 1 recognize which type of ROOM TAG is used in a given room
step 2 allow the changing of room tag type in a schedule and have it change in the room view.
we have 6 types in 1 room tag, each serves a purpose for code, net sq/ft, gr sq/ft.
each view would require the correct room tag type to be present in each view based on occupancy/ Code review, Department and Usage etc.
thank you
Nachricht 6 von 8
kadmonkee
als Antwort auf: barthbradley
thanks
i got it to populate in the schedule as a selection but not as a live tracking option in the rooms.
but that process was not worth the results
thank you
Nachricht 7 von 8
rxi.gg
That is not possible because you can use several tags in the same room, as @barthbradley said, tags are view specific elements
Nachricht 8 von 8
kadmonkee
als Antwort auf: rxi.gg
thanks
was not sure but had to try
thank you
