Room Tag - parameters greyed out
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
3953 Aufrufe, 6 Antworten
Hi - and appreciate any help with this one....
We need to add two Room Numbers for one Tag and this has not worked for us at all and its beyond me why but think missing a step somewhere....
Created new tag and added parameters by creating a new one from category parameters. Previous to this we created 2 new shared parameters as a test as it wasn't working for us:
1. Room Tag 1512 - Common  / text
2. Room Tag test 1513 - Common / text
Both labels placed in the tag...and in turn into the project. Both new parameters are greyed....
fine...so went into project parameters....added shared parameters
1. Room tag 1512 - as instance / values are aligned per group type / group parameter: identity data / categories: areas
2. Room Tag test 1513 - as type /  group parameter under Graphics / checked all in categories
Parameters are still greyed out.  What step are we missing?
6 ANTWORTEN 6
Nachricht 2 von 7
Sahay_R
als Antwort auf: Anonymous
Did you need the Room Tag to show 1512 and 1513? Just put then in as static text instead of labels.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 7
Both of the shared parameters must be added in projects as instance, not type, and check Room category, not Area or All.
Nachricht 4 von 7
als Antwort auf: Sahay_R
no we have 50 rooms to tag. The image i sent is just a setup to try to get the tag to work.
Nachricht 5 von 7
als Antwort auf: ToanDN
It was the room category that was throwing it off. For some reason was convinced it was areas. Thanks!
Nachricht 6 von 7
Just curious, why don't you use the system Room Number for one of the two?
Nachricht 7 von 7
we are. I set up 2 different ones as we were trying different things to both to see what the issue was.
