Room tag is outside of its Room error not resolving with leader lines
4 ANTWORTEN 4
Nachricht 1 von 5
Samantha_Melcher_ZU9YNH2U26WT
260 Aufrufe, 4 Antworten
I've got a bunch of "room tag outside of its room" errors in a model that I'm trying to resolve.
Usually I would resolve this by
1. selecting the room tag
2. checking the leader line box in properties
3. uncheck the leader line box
4. room tag gets sent back to the center of the room element & warning goes away
However in this model when I follow this process, the room tag snaps back to the center of the room, reads all proper information, but the warning/error does not go away and gives the "tag outside of its room" error. Does not seem to be an issue with the room or tag, as I'm able to add a new instance of the same tag family to the same room without issue.
Working in Revit 2023.
Any ideas?
4 ANTWORTEN 4
Nachricht 2 von 5
Nachricht 3 von 5
Room is not in a linked model.
Nachricht 4 von 5
Nachricht 5 von 5
Yes, this is what I have already tried that is not working.
