Room tag family showing two dimentions in one
2 ANTWORTEN 2
Nachricht 1 von 3
dariawerynska
358 Aufrufe, 2 Antworten
Hi there!
I have an attic floor where part of the surface is counted as 100% and part of it in 50%.
I made the room schedule adjusted to this requirement but I don't know how to adjust a room tag to it so that it would be one tag counting two areas.
In order to have the desired room schedule I created 2 parameters:
- first named Coefficient : (project parameter, number value) marked as "1" for regular spaces and "0.5" for those attic parts
- second named 50% (shared parameter, yes/no) specyfing which area should be considered as 50%
In the schedule I added a calculated parameter for 50% which goes as follows: Coefficient *Area - I then renamed it in the schedule formatting as "True Area" and marked "calculate totals". This works well in the schedule but I don't see a way of how to make use of it in room tagging :verwirrtes_Gesicht:
Do you have any advice? :leicht_lächelndes_Gesicht:
Tags (2)
2 ANTWORTEN 2
Nachricht 2 von 3
jedry
als Antwort auf: dariawerynska
Hi Daria,
The Process is simple:
1. Edit the Room Tag family
  • Create a Label text for the Real Area
  • Create a Shared parameter named as "Coefficient" (NUMBER)
  • Create a formula value "Area*Coefficient"
  • Reamed the Room Tag Family
  • Load the new family into the project
2. In the project, create a project parameter (Instance parameter)
  • Choose the same Shared parameter "Coefficient" used in the Room tag Family
  • Aplly just for Rooms
3. Tag a Room using the new Room Tag
4. Change the Room instance Property value "Coefficient" to 1 or 0.5
Tags (1)
Nachricht 3 von 3
jedry
Files.
Good Luck
