Hi all,
I have a problem with room tags and color scheme. The problem is that colored hatches of color scheme appear on top of the room tags on the fırst basement level which is not the case on 2nd basement level. See pictures
Disclosure: My teammate and I work on this project through worksharing on office network. I duplicated with detailing these two floors specifically for color scheme. She put all the room tags on the second basement level and I did the color scheme on the same level. For the first basement level, I did both tagging the rooms and creating color scheme.
I am not sure if the problem occurs because she placed the tags on the duplicated view and I worked on the original view when putting the room tags.
You have to tag the views again with Room tag..
Two views if not " Dependent" then the annotation wont show up on both..
Just retag..
Cheers!
