Room Tag Automatic Leader
I am wondering if there is any way to have a room tag automatically create a leader once you move it outside of its host room. It's very annoying when the warning message pops up and you have to hit OK and the  check the leader option in the properties. Is there a way to make this automatic?
Thanks.
Yes, this would be nice to have.
Seems that this was added to the Revit Ideas already: https://forums.autodesk.com/t5/revit-ideas/adding-a-leader-from-prompt/idi-p/7530655
Corsten.Au
Hi
am not sure whether this will help, but While " Tag All "
in room tagging you can tick for Leader.
Cheer!
Corsten
Building Designer
RobDraw
Train yourself to activate the leader before dragging the tag outside of the room.
Rob
So far, this is the most helpful solution..
Thanks!
