after placing it i find out it does not align with interior edges of the wall and would like to correct it but on selecting it it don't get an option to edit it. what am i doing wrong ? is this not doable in revit lt?
thx
This article may help: REVIT TAGS ROTATE WITH COMPONENT.
It is not clear from your original posting whether you are not able to change the rotation or the position of the wall tag after having created it.
Could you send a screen capture of the problem?
-luc
Room tags have nothing to do with walls. They orient horizontally or vertically in relationship to the View. Wall tags, however, can align with walls orientation.
I miswrote when i referred to 'room tag' what i really meant is the room boundary lines not completely aligning with some of the walls of the rooms they enclose . i thought i could select it and then edit the individual lines to align with the interior of the enclosing walls.
